Here is a script that will download and run Vipre Rescue. It is not automated yet but It can be and I might do it. It saves to the users desktop.
Bill, you might like this one.
Vipre Rescue
Vipre Rescue
- Vipre Rescue.uvk
- Download Vipre Rescue
- (837 Bytes) Downloaded 828 times
Re: Vipre Rescue
Can you delete this? It no longer works and I can not figure out how to get it too. Don't have that much time to spend on it.
Re: Vipre Rescue
Hi Jim,
This is what I have and it just works.
Re: Vipre Rescue
Is vipre a good program? I have a client who got a lifetime license to the antivirus from the shopping channel for 100.00. Thought it was a scam but now I see we recommend vipre rescue.
Re: Vipre Rescue
In my opinion Vipre rescue is very good. I don't use it regularly because it takes a long time to run. Of coarse I refer to Rescue and not the normal AV program but Rescue is a stand alone version of the full AV program. 100.00 is certainly not a bad price for it as long the subscription status is valid and everything looks legit.
I have had Vipre Rescue clean stuff when I knew the computer had an issue and nothing else found it.
Re: Vipre Rescue
I will have to try that. I made the script because It didn't work for me before and now the script don't work so I will go back and try that one again and see what happens.
Thanks fer the pic.
Thanks fer the pic.
Re: Vipre Rescue
I couldn’t get it to work either and I got help getting that to work some time ago.
Re: Vipre Rescue
Bill, post one more time and you hit 100.
