Crash Dumps
Muhammad Tasneem
Crash Dumps
Post by Muhammad Tasneem »
hi,
I have seen that my CrashDumps folder "C:\Windows\System32\config\systemprofile\AppData\Local\CrashDumps" near 1GB and not clear after repair/maintenace scripts.
I don't know it is save or not to delete files under this folder.
Re: Crash Dumps
Thanks for the suggestion, Muhammad. Will be added to the next update.
Take care.
