Hi there! So if you have, all or recommended immunization on, on UVK, MalwareBytes AntiMalware scan doesn't install properly. You need to deactivate the Immunization for it to work.
I Hope this helps you out.
Bruno Santos
MBAM scan doesn't work if you have Immunization On.
Re: MBAM scan doesn't work if you have Immunization On.
Thanks for this information Bruno, I did not know recommended would mess it up, I did know all will for sure.
Be safe and well friend.
Bill, it didn't until now. They must have changed something recently.
Hi and thank you Bill.wmmiller wrote: Thu Jan 23, 2020 4:13 am Thanks for this information Bruno, I did not know recommended would mess it up, I did know all will for sure.
Be safe and well friend.![]()
About the immunization, my dad is right. It's something recent they changed.
I hope you are okay!
Bruno
Slightly related,
Malwarebytes showing UKV as maleware.
File: 1
Malware.Generic.3992703781, C:\PROGRAM FILES\UVK - ULTRA VIRUS KILLER\CLEARDISKINFO.EXE, No Action By User, 1000000, 0, 1.0.25100, C732E8B77DF411D1EDFBD325,
File: 1
Thanks for reporting this, Trajet. Cleardiskinfo.exe no longer seems to be detected. https://www.virustotal.com/gui/file/224 ... detection/
If you find out otherwise, please report the false positive to them here: https://forums.malwarebytes.com/forum/4 ... etections/
Thanks again.
Thanks again.
