Nsis Error Launching Installer error
Hi Guys,
Has anyone seen this error before? I don’t recall ever seeing it before. It just noticed it trying to install my remote support software update. (SimpleHelp). Just for fun I tried to launch the installer on another computer with this same error. (Both 64bit)I could be wrong but the only thing I can think of that these two computers have in common is I updated Malwarebytes, SUPERAntiSpyware, Windows Defender and UVK. I Binged around some but honestly haven’t spent much time on this yet. Do you guy have any experience with this one?
Thanks, Bill :)
FYI: Both Windows 10 64bit.
Re: Nsis Error Launching Installer error
Hi Bill. Does the installer pop up the UAC prompt automatically? If not, it may be worth to try right-click -> Run as administrator. Also check if Execute prevent is not blocking some related files in %appdata%.
That was my first thought. I disabled execute prevent and UAC is/was off and rebooted and still come up with the same results. I also tried run as administrator and disabled Malwarebytes and SUPERAntiSpyware but thinking back I don’t think I disabled Windows Defender. I’m pretty busy today and don’t have much time to mess with this right now but if you or anyone has any more ideas, I would love to hear them.
Thanks, Bill
I would say that we can forget about this issue. Just for fun and after screwing around with it and trying different things I decided to use a clone from June on my SimpleHelp server to see if the issue was still present and it is. I’m going to with this being a corrupt file that is being offered for download. I downloaded it several times and it’s the same thing. I emailed the SimpleHelp people to let them know I believe there is an issue so I will see what they say.
Thanks, Bill
OK, Bill. Hope they'll fix it up soon, if that's the case.
This is what I was told:
“Hi Bill,
You could try:
SimpleHelp-install.exe /NCRC on a command line to see if that works?
Thanks, George”
Ok, that works but still leaves the question of why the installer of two version ago work fine but this one wont. (Just tested it.) I’m not a programmer but it sure seems like there is an issue with this install. If it was a windows issue that cropped up, shouldn’t the previous version fail as well? Since I don’t know anything about programing, it’s hard for me to know if I’m just being stupid or if it is indeed an issue with the installer.
PS: The MD5 matches.
Bill,
Since I am busy today as well, I'll just drop a quick note and say, it IS an installer issue. I kow this because an older one worked fine and George asked you to add a command-line switch to the installer. That switch I am guessing disables the the installer CRC check.
Thank you Fred. :D
Just to follw up on this. This is where its at for now.
Hi Bill,
No, I don't know why. The install is working here on all our 64bit test servers, and we've not received any other reports about it yet.
This error indicates a CRC error. The installer is expecting the data to produce a particular value, but it is not. I've read a bit about scenarios why this might occur on a certain machine, but I don't really have any indication as to why it is happening yet.
Thanks,
George
