I would like to see a feature added that enables UVK to do the following:
-Back-up all Wireless Names and Passwords
-Recover a Back-up
(So that for example I can connect one pc to a 10 networks, then copy and add the networks to many pc's using UVK)
I hope you can make this happen .
All Best,
Martijn
Wireless Key's
Re: Wireless Key's
Nirsoft's WirelessKeyview has these features.
Re: Wireless Key's
Hi Martijn.
This is exactly the kind of feature I want to avoid coding, because it is malware-like behavior. I know you have good intentions, but security programs don't care about that. Nirsoft has most of the tools flagged because of that.
And, as Xander mentioned, WirelessKeyView already has those features, so there's really no need to re-invent the weal. WirelessKeyView is part of TTS, and it is easy to add to UVK as a custom third party app.
