uak
csm
uak
Post by csm »
Hi fred and others,
I am using a script to automate uak. Works fine until version 5. I had to edit the script to get it to work again, no problem. But in noticed that there was new screen that will ask for an immediately reboot after some malware detection. Is it possible to disable that by commandline switch, because there are other programs that will run after uak.
Re: uak
CSM, You can click No in that screen, to reboot later.
csm
Re: uak
Post by csm »
Yes i know, i have to edit my script again, add an "if then" .
Just wondering if there was a switch.
Re: uak
CSM, that screen has always been there. There's no switch to cancel it.
