No sound after Windows 10 upgrade
FredJClaus
Post by FredJClaus »
Recently got a call from a client about upgrading to Windows 10. After he did, his sound card did did not work. He got the message "No Output device was installed". It took me a while and a few failed attempts but I fixed it. I thought I would share here how I fixed it so others might also have the information.
I can solved as following.
1. Select IDT High Definition Audio CODEC on Device Manager.
2. Select Driver tab.
3. Click Update Driver... button.
4. Select -> Browse my computer for driver software.
5. Select -> Let me pickup a list of device drivers on my computer.
6. Select High Definition Audio Device (Not IDT High Def... this is important.) and click Next.
Appears Warning message, but reply Yes.
7. ! Windows has successfully update your driver software.
Key is step 6.
Re: No sound after Windows 10 upgrade
There are a couple network cards that need generic drivers as well. When I run across one I'll post on it.
I don't think you guys should treat this as a permanent issue. What happens is that the manufacturers of those devices haven't made a driver for Windows 10 yet, and the previous driver is not compatible. As soon as they build a Windows 10 compatible driver, the problem should be automatically solved.
I wasn't trying to imply it would stay that way. For me it was more of a suggestion that if windows 10 did not recognize your hardware, it will prolly work with the generic driver ;)
FredJClaus
Thanks for the information Fred.
